Altair RISE
Nominate Yourself Now!
Setting Pressure Inspire shutdown
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I'm trying to set a tologic optimization in Inspire, I've set the fasteners and when I try to define pressure on any surface the program shutdown without any message.
The problem persists trying to set it on a simple solid.
Any suggestions?
Thanks.
Alberto
1 - 6 of 61
    User: "Matthieu Pupat"
    Altair Employee
    Updated by Matthieu Pupat
    HI Alberto,
    Please let us know your graphics card model and drivers version.
    Thanks,
    Matthieu
    Altair Employee
    OP
    I'm working on a Macbook Pro with NVIDIA GeForce GT 750M 2048 MB.
    NVIDIA GeForce GT 750M:
      Modello Chipset: NVIDIA GeForce GT 750M
      Tipo: GPU
      Bus: PCIe
      Larghezza canale PCIe: x8
      VRAM (dinamica, massima): 2048 MB
      Fornitore: NVIDIA (0x10de)
      ID dispositivo: 0x0fe9
      ID revisione: 0x00a2
      Revisione ROM: 3776
      Cambio automatico scheda grafica: Supportata
      Versione gMux: 4.0.8 [3.2.8]
      Metal: Supportato, set di funzionalità macOS GPUFamily1 v4
      Monitor:
    LCD colori:
      Tipo di monitor: LCD Retina integrato
      Risoluzione: Retina 2880 x 1800
      Profondità buffer fotogrammi: Colore 24 bit (ARGB8888)
      Monitor principale:
      Duplicazione: Non attiva
      Attivo:
      Rotazione: Supportata
      Regola automaticamente la luminosità: No
    Altair Employee
    Which version of Inspire are you using?
    What is the version of your graphics drivers?
    Altair Employee
    OP
    Hello Matthieu Pupat and thanks for your answer,
    I'm working on Inspire 2017.3.2 and the graphic drivers are VMware SVGA 3D ( I'm using VMware Fusion version 11.0.2  on MacBook Pro).
    I've run Windows, VMware, and even the Mac updates.
    Any advice?
    Thank you very much.
    Altair Employee
    The latest version is Inspire 2019.0.1 and we improved graphics a lot.
    Usage of VMWare can also be an issue for graphics bugs during picking.
    Unfortunately this is not supported on MAC and will require that you switch to a Windows machine.
    Altair Employee
    OP
    Matthieu Pupat thanks, it was my fear.
    I'll try to download the last Inspire version.
