Altair RISE
Nominate Yourself Now!
HM Script to write out seperate *.stl file for each component
User: "Jey"
Altair Community Member
Updated by Jey
Hello,
I have 150 list of components ( one comp per comp collector) in hypermesh. Need to write out seperate *.stl file for each component with Component Collector name followed by Materialname and thickness
i.e Comp Name: Wheels, Material Name -Steel; Property Name - Wheel_Shell with Property values, E, V & Thickness = 3 mm.
Need to write filename of part: Wheels_Steel_3mm
If above said is complex, need script to write out with component name only.
