🎉Community Raffle - Win $25
Join and Win
HM Script to write out seperate *.stl file for each component
User: "Jey"
Altair Community Member
Updated by Jey
Hello,
I have 150 list of components ( one comp per comp collector) in hypermesh. Need to write out seperate *.stl file for each component with Component Collector name followed by Materialname and thickness
i.e Comp Name: Wheels, Material Name -Steel; Property Name - Wheel_Shell with Property values, E, V & Thickness = 3 mm.
Need to write filename of part: Wheels_Steel_3mm
If above said is complex, need script to write out with component name only.
1 - 4 of 41
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    It's not so complicated. Here're some ideas:
    The following command disables output for component ID=5:
     *setvalue comps id=5 outputsuppressed=1
    Example of STL export:
     *createstringarray 2 'CONNECTORS_SKIP' 'HMMATCOMMENTS_XML' *feoutputwithdata 'C:/Program Files/Altair/2020/hwdesktop/templates/feoutput/misc/triasto.stl' 'C:/Users/Me/test1.stl' 0 0 2 1 2
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    Try the attached script for your case.  Adapt it as needed.
    #get altair home directory
    set home_dir [hm_info -appinfo ALTAIR_HOME]
    #set output_folder {d:/Adriano/Macros}
    set output_folder [tk_chooseDirectory]
    #select components and store in a list
    *createmarkpanel comps 1 'Select components to export:'
    set comps_list [hm_getmark comps 1]
    *clearmark comps 1
    #foreach component in the list
    foreach compo $comps_list {
        #isolate compo
        *createmark components 2 $compo
        *createstringarray 2 'elements_on' 'geometry_off'
        *isolateonlyentitybymark 2 1 2
        #retrieve compo data
        set compname [hm_getvalue comps id=$compo dataname=name]
        set matname [hm_getvalue comps id=$compo dataname=property.material.name]
        set thick [hm_getvalue comps id=$compo dataname=thickness]
        set thick [format %2.2f $thick]
        set exportname '${compname}_${matname}_${thick}'
        #export model as STL
        *feoutputwithdata [file join $home_dir 'templates/feoutput/misc/triasto.stl'] [file join $output_folder '${exportname}.stl'] 0 0 0 1 2
    #endforeach
    User: "Jey"
    OP
    Updated by Jey
    Thanks
    User: "Jey"
    OP
    Updated by Jey
    *clearmark comps 1
        #isolate compo
    #endforeach
    Thanks
