postprocessing of abaqus result file in hyperview
Hi,
I have gone thru the hyperview post processing document where corner data & averaging method is explained for shell and solid element.
Those explanations are bit confusing.
Please clarify if I have done static analysis of Floor assembly in Abaqus & have .odb result file and want to do post processing in Hyperview.
Then in Abaqus CAE, I am quoting the stress as Simple average (75%).
To correlate same result,which option is best tin Hyperview-
1) Corner data should be on or off?
2)Averaging method should be simple,NONE or Advanced?
3) which combination of corner data & averaging method.
I tried with all options and I got 20% deviation in hyperview.
Thanks in Advance.
Regards
Dheeraj Pandey
1 - 1 of
11
Hi,
I would say it must be:
1) Choose 'Stress components IP (s)'
2) Corner data --> OFF
3) Turn on Simple average
Regards
