interactive 2D mesh
Hi All
working on 3D flange having holes..i m trying to write script for 3D mesh of it..
process i am following is :
1. washer split for holes.
2. 2D Automesh surfaces
3. Solid map
I want 2D Automesh process to be interactive so that user can adjust mesh around holes to create good washer..
How can i do this..?
Regards,
PD
When you use hm_pushpanel to invoke panel 'automesh' to help user to adjust mesh, hm_pushpanel will return soon and not wait for user finish his work.
=> do not use hm_pushpanel, you need to pack all remained script into hm_setpanelproc
example:
eval *createmark surfs 1 $::FlangeSurfs
set Holes [p_GetHoles surfs 1]
hm_entityrecorder surfs on
p_SplitHoles $Holes
hm_entityrecorder surfs off
eval lappend ::FlangeSurfs [hm_entityrecorder surfs ids]
hm_setpanelproc {
hm_setcollector automesh [hm_getcolnumber automesh 1] surfs
hm_initpanel {
hm_activateitem [hm_getitemnumber automesh mesh]
hm_callpanel automesh
eval *createmark elems 1 {'by surface'} $::FlangeSurfs
p_SolidMap elems 1
Can you do this without script?
