Hello everyone
As there is convection, I use MAT4, which also contains the heat transfer coefficient H. Now I am woundering, how can you specify two different heat transfer coefficient on certain surfaces of the model?
The heat transfer coefficient is actuallly not a material property, so I am woundering if this is the right way to go. How can two different heat transfer coefficient be assigned?
Thank you in advance for your help!
