I have created a double sided fillet weld geometry with three plates. This was modeled using solid and shell plate techniques. The case belongs to a normal tensile loading (along X direction as per global coordinate system). Hence, it should ideally possess sigma XX in both the cases. But stress (sigma XX) in shell model is almost 0.25 times the stress obtained in solid model. The stress has been determined at a point farther away from weld, so weld modeling would not be affecting the value in the two cases. This ratio has been consistent even at different load values. I have also iterated the element size varying from 0.5 mm to 3 mm but the deviation has been consistent. So, mesh refinement might not be the reason for this. Please anyone enlighten me with the possible causes.
Thanking you in anticipation.
P.S : I have attached the simulation file (.fem files) for both the cases.
Regards
Venkatesh
