With version 12 of Radioss bulk have limited material model.may be latest version14.0 would have some more on Rubber (Hyperelastic material MATHE)
With Radioss solver you can check same.
The Neoprene rubber can be modeled with :
• material /MAT/LAW42, /MAT/LAW62 + VISC/PRONY in case the material almost incompressible (Poisson ratio = 0.495)
• material /MAT/LAW38 or /MAT/LAW70 in case the material highly compressible (Poisson ratio = 0)
• material /MAT/LAW38 in the other cases.
Compression test with different load speed are necessary to define the material. The compression test should be conduct up to densification phase. Any other test (tensile, shear, frequency answer, relaxation test,…) will help to better fit the material law.
Which version of Hyperworks you are using?Radioss bulk rebranded as Optistruct.
