Altair RISE
Nominate Yourself Now!
Create Node Sets that import into abaqus v12
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I am trying to import my model into abaqus and create a contour integral crack card. I am having issues with getting abaqus to import the entity set from hypermesh. Does anyone know a way to get this entity set to import into abaqus so that I can simply select it as the node set instead of selecting each node individually?
Thank you
1 - 4 of 41
    Altair Employee
    OP
    Sets did export as needed just did not show up in interface. Can still be selected by using sets in crack creation menu
    Altair Employee
    OP
    Hi Cer54,
    What is the version of HyperWorks are you using and what are the updates for the same?
    Please use the link below for information on how to check for updates:
    http://forum.altairh...n-your-machine/
    Also, what is the version of Abaqus are you using to import the model?
    Altair Employee
    OP
    HyperMesh v12 and Abaqus 6.13-1. I am unsure of updates since its the university copy.
    Altair Employee
    OP
    Cer54,
    So when you try to select the sets from Interface the sets doesn't show up in Abaqus, right?
    Do you see sets in model browser when you import the same in HyperMesh?
    What is the set type you have created in HyperMesh?
