Missing elements hyperview
User: "Amaya"
Altair Community Member
Updated by Amaya
Hi,
I created a model using hypermesh 2019.1, export solver deck .inp format and then ran it with abaqus.
I tried to view the result .inp and .odb file with hyperview, but some of my elements when missing when I ran it in hyperview. It was fine in hypermesh.
what should I do? What is the problem?
thankyou.
1 - 1 of 11
    User: "Chayan"
    Altair Employee
    Updated by Chayan
    Hi Amaya,
    As a sanity test can you import the inp file into a clean HyperMesh session? It is possible that those elements did not get exported to the inp file.
    If that is indeed the case, then take a look at the elements, make sure they have the correct element type definition, have properties assigned to them, and are not in a component that is set to do-not-export.
    Hope this helps guide you in the right direction. Let us know what you find.
    -CB
