Fields
I try to transfer and interpolat the forces and moments from a coarse model to the submodel by 'Fields-->realize'.
In the coarse model I set ELFORCE and GPFORCE in Globa_outpu_request to *.h3d file.
If I try to interpolate the Element Forces (2D) P1 (Major) no Forces were written in the loads.
Which Forces do i have to apply it to the submodel?
1 - 5 of
51
Hi @Oli
Can you change the tolerance and check if you are able to map?
If you still face the issue, please share the files with us.
I checkt that already. Unfortunately it doesn't work.
Attached are the *.fem and the *.h3d from the coarse model and the *.hm from the submodel where I want so Transfer the Forces and moments on the set of nodes.
Hello,
Can you please tell me which solver are you using and what kind of analysis are you trying to do?
Thankyou
