🎉Community Raffle - Win $25
Join and Win
Can HyperWorks run the Abaqus Topology Optimization?
User: "Golden_Tan"
Altair Community Member
Updated by Golden_Tan
I know Hyperwoks can run topology optimization in Optistruct user interface.
But i wanna run an topology optimization in Abaqus user interface because the model have multiple contact areas.
I know in Abaqus pre-process it self can run topology optimization, shows below:
Can Hyperworks under Abaqus User interface can do topology optimization ? (Not in the optistruct user interface)
1 - 4 of 41
    User: "Paulo  Libório"
    New Altair Community Member
    Updated by Paulo Libório
    Hello Xingpeng,
    HyperMesh writes the solver deck for the intended solver, but doesn't run it. For Altair solvers, you can submit jobs from the HyperMesh interface, but this isn't valid for other solvers, such as Abaqus. You need to export the solver deck, then submit the job to Abaqus solver or import it into Abaqus CAE, for finishing touches and submitting the job.
    Regards,
    Paulo Libório.
    User: "Golden_Tan"
    OP
    Hello Xingpeng,
    Regards,
    Paulo Libório.
    Hello Paulo Libório:
            i am just follow your instruction:
           1. Prepare a run able Abaqus inp.
           2. Import to Hypermesh Abaqus interface.
           3. Switch Abaqus interface to Optistruct interface.
           4. Create topology Optimization under Optistruct interface
    and i got the following problem:
    i create the topology optimization under Optistruct , that's fine.
    when i switch back to Abaqus Interface
    no information under the Design Variable, Objects, and Response.
    also when I export the inp files under Abaqus interface , i open it with UltraEdit and check the data, no Optimization data.
    I know Optistruct code is based on the format of nastran which is not compatible with abaqus code.
    so under Optisturct interface to create Topology Optimization and switch back to abaqus interface can't work.
    Optistruct only can do the linear problem optimization , but i want to run the topology optimization under nonlinear problem
    Xingpeng,
    A couple of things:
    Changing the solver interface does not convert the deck. For converting decks, you should use the Convert option:
    Check the Help Documentation regarding conversion:
    OptiStruct to Abaqus Conversion Mapping ←→ Abaqus to OptiStruct Conversion Mapping
    My suggestion was to create an Abaqus .inp in HyperMesh and then export to Abaqus CAE, to finish your setup for the entities not supported by HyperMesh.
    Regarding Optimization, please check Optimization Entities to see which entities and for what solvers HyperMesh is able to define.
    Kind Regards,
    Paulo Libório.
    User: "Golden_Tan"
    OP
    Xingpeng,
    A couple of things:
    Kind Regards,
    Paulo Libório.
    Thank u for u clarify, i hope all the abaqus optimization set up can be done by hypermesh, but now i know it is impossibled.
