How do I pull out an alpha prefix from an alpha-numeric chr field?
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
I have a character field (client account number) that is made up of an alphabetic prefix followed by numbers. Since I need to leave the client account number intact, I trying to find how to create a calculated field that pulls in only the alpha prefix. The length of the alpha prefix varies from 2 to 5 characters.
Below are a few examples:
DOT032440
PC14888
RHEA789442
LAWNV7894457
I would appreciate any help available. Thanks,
Diane
1 - 1 of 11
    Altair Employee
    OP
    Hi Dianne,
    If the alpha characters are always at the front, then a combination of the Extract and Strip function so do what you need.
    Strip("ABCDEFGHIJKLMNOPQRSTUVWXYZ",[Client Account Number]) will result in the following values:
    032440
    14888
    789442
    7894457
    Embedding the strip within the following extract function will extract from the start of the string to whatever the strip function returns.
    Extract([Client Account Number],””, Strip("ABCDEFGHIJKLMNOPQRSTUVWXYZ",[Client Account Number])).
    There will no doubt be a more concise RegEx expression that will offer greater flexibility if this doesn’t do what you need.  Please let me know and we can look into that if required.
    Regards,
    Steve.
