🎉Community Raffle - Win $25
Join and Win
Forces at 45 degrees
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hey guys,
I'm trying to apply a force at 45 degrees to either edge but can't figure out how to do it. Any help would be greatly appreciated.
I've attached an image, the arrow in red is what I want!
Thanks :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20'>
1 - 6 of 61
    Altair Employee
    OP
    define a local coordinate system or apply forces in x and y direction so that together they form the resultant force vecor
    Altair Employee
    OP
    Thank you, how does one define a local coordinate system?
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Hi,
    To create LCS use Analysis page: System Option.See attached screenshot.
    You can apply forces directly while defining direction using two nodes as well.
    Regards
    Rahul R
    Altair Employee
    OP
    I'm trying to define them so they run at a 45 degree angle but can't figure out how to do it :mellow:/emoticons/default_mellow.png' title=':mellow:'>
    Since you don't have any reference for defining inclined path or geometry.you can use rotate option to rotate node with 45 degree and then choose two  as n1 & n2 to define a incline direction.See attached screenshot.
    Regards
    Rahul R
    Altair Employee
    OP
    Thanks very much Rahul! Where can I find the rotate function?
    EDIT
    Ah no worries! I think I've figured it!
    Thanks so much
