🎉Community Raffle - Win $25
Join and Win
analysis crashes
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
I am using inspire to optimise a rocker model, but each analysis terminates at 40% completion and 'hvtrans.exe has stopped working' window pops up.
Can you tell me what's wrong with my model and how to fix this please?
Thank you
Yan
1 - 6 of 61
    Altair Employee
    OP
    Hi YanYang2,
    could you please let us know which version/build of sT Inspire are using?
    to check the build of sT Inspire, Go to Help and click About to view version and build details image/emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    Yan,
    Please see if you can also share the model using the secure dropbox link below
    Altair Employee
    OP
    Hi Prakash,
    I am using ST inspire version 2014 build 3959.
    Hi Rahul Ponginan,
    I will try and upload now.
    Thanks
    Altair Employee
    OP
    Hi YanYang2,
    can you install the latest build Inspire (3969) from http://www.solidthinking.com/DownloadProducts.aspx?category=Download&item=Products
    Run the optimization again and check if you are able to get results without errors.
    if you still face the problem, please let us know.
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    yanyang2
    Please also make sure the load is applied on non design components, i.e. components that are not selected for design (right click design)
    This means, that if you want to apply a force in a cylindrical hole , you will need to create a cylindrical bush component, it is not advised to apply loads and support as you have all in one component marked as design.
    Altair Employee
    OP
    Thank you Prakash and Rahul, that was really helpful! It was my applied load and support on the model that caused the problem as you suggested.
