🎉Community Raffle - Win $25
Join and Win
Hypermesh to ansys APDL (Geometry and elements)
User: "hiranwale_bharat"
Altair Community Member
Updated by hiranwale_bharat
Hello,
Is it possible to export Mesh and geometry created in HM to ansys APDL (In .cdb format)
Thanks and regards,
Bharat
1 - 7 of 71
    User: "Sanjay Nainani_20973"
    New Altair Community Member
    Updated by Sanjay Nainani_20973
    Hello,
    If you are in Ansys User Profile and the element have the correct ET Type assigned then you can directly go to the export panel and export it to .cdb format.
    If you are in OptiStruct User Profile. First go to Tools>>Convert>>OptiStruct>>To Ansys
    and convert the model.
    This will bring you to the Ansys User Profile. Now you can export it as explained above.
    Thankyou
    OP
    Thanks Sanjay for the reply.
    I have tried using the method which you explained but I can find only the elements in APDL, not the geometry.
    Do you have any suggestions on this?
    Thanks and regards,
    Bharat
    User: "tinh"
    Updated by tinh
    You can export geometry to IGS file and import it to ansys
    select 'Export Geometry' on the menu
    OP
    Hello Tinh,
    Is it possible to export mesh and Geometry at the same time (or in the same file) from HM to APDL?
    Thanks and regards,
    Bharat
    User: "tinh"
    Updated by tinh
    I don't think it is.
    you can export mesh+geom to hm ascii file but ansys may not read that format
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    Hello Tinh,
    Thanks and regards,
    Bharat
    Mesh and CAD are NOT the same, you can not save them into the same format for APDL.
    Do export separately.
    OP
    ok. thanks everyone.
