1 - 5 of
51
I watched few tutorials from your side in acusolve, While postprocessing you guys are importing corresponding log file. I'm not getting that particular file after running a simulation. I hope its clear now, How to get that log file can you please assist me to sort out this issue?
Which software are you using to start the AcuSolve job? And which version?
If you're running from SimLab - you right-click Solution and select 'Go to Solution Directory' (or something along those lines). That directory would contain the .Log file and other solution files.
Hi @Sreekrishna I am moving your question to the AcuSolve topic to get more help from our community members.
