I got a question. I set up a composite size optimization for a door structure. But when I want to run it, the solver only conducts an analysis, stating ANALYSIS COMPLETED at the end. Can someone help? Run option is of course "optimization"
Are you sure you have the optimisation variables set (correctly), are there any messages in the out about 'no optimisation variables found'?
If you can share your .hm we can take a look, if you can't share the .hm, then the .out file would give us more to go on
