Altair RISE
Nominate Yourself Now!
Non selected surface
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I must select the all of surface in the hole. I attached the pictures. Blue surfaces will be nondesign_surface. Half of the hole is pink which is design space. However it should be blue which indicates the nondesign area.But half of the hole which i marked red circle could not selected by manuel usuage. How can i select this nonselected surface (red circle area)?
Could you help me?
Please answer as possible you can,
Thank you
1 - 7 of 71
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Your geometry is 3D (solid) and you're trying to define design/nondesign zones over surfaces?
    Altair Employee
    OP
    Yes, one solid and the hole should not change after optimization ,so i want to define nondesign surface
    User: "tinh"
    Updated by tinh
    F2>delete>solids to delete all solids then you can select the surfaces manually
    Altair Employee
    OP
    This is for deleting solid? Because when i tried the surface, it is gone and i could not trim
    User: "tinh"
    Updated by tinh
    When a solid existing you cannot delete surfs be cause they belong to the solid
    When you work with solid elements, I think you have to define design/non-design area on solid elements, not surfaces.
    Altair Employee
    OP
    I picked the components, and i did define thank you all attention
