1 - 7 of
71
I have attached two igs files to this post:
01- Block (http://www.filedropper.com/01-block)
02- joint (http://www.filedropper.com/02-joint)
The block is needed to be meshed with Octree type mesh, finer brick elements will be in touch with joint and those block are going to be meshed with tetrahedral elements.
Hi,
Hypermesh 13.0 version support Octree Based Tetra Mesher.New tetramesher option octree based has been added to the Tetramesh and CFD Tetramesh panel. It provides smooth element transition with good quality tetras. In general it is faster compared to the standard setting (advancing front).
Please refer below link to see online video.
http://www.altairhyperworks.com/training/new_feature_videos/13/content/cfd.htm
Regards
Rahul R
