Is it possible to do Octree meshing in Hypermesh?
if yes which part of the Manual should I refer to?
New tetramesher option octree based has been added to the Tetramesh and CFD Tetramesh panel. It provides smooth element transition with good quality tetras. In general it is faster compared to the standard setting (advancing front).
Please refer below link to see online video.
http://www.altairhyperworks.com/training/new_feature_videos/13/content/cfd.htm
Regards
Rahul R
Hi Rahul,
Thank you so much for your reply.
Best regards,
Attila
Could you tell us for what type of analysis this type of mesh is needed?
Geotechnical analysis of soil, rock, and structural support in three dimensions.
Thanks,
I have attached two igs files to this post:
01- Block (http://www.filedropper.com/01-block)
02- joint (http://www.filedropper.com/02-joint)
The block is needed to be meshed with Octree type mesh, finer brick elements will be in touch with joint and those block are going to be meshed with tetrahedral elements.
Thanks for sharing information.let me check internally and update you.
any news?
