Hi there,
Is that possible to assign a tapering(varying) thickness for a shell element.
Thanks in advance
hi,
it depends on solver. In dyna, just activate ununiform thickness in section card
but i never ever see it applied, has particular purpose perhaps
It's possible to do that with SAMCEF solver too. But I can not found the simple way to distribute variable thickness to shell elements.
I have to write myself a TCL script to determine good thichness at node and make a correct card for each element.
Both of you Thanks for your valuable suggestion,
Sorry for the late response,,..
Like wise, Is there any card to do the same in radioss,,..
Hi,
Finally I got the answer for my question, Here is it have a look.
There are 2 options to do so
1) Menu bar>mesh>create>midsurface>
2) Utility menu>Geometry mesh>midsurface thickness
Note: need to create a dummy property named as “t0” and the property as Pshell (no need to give any value for thickness, leave it as is.
1)Menu bar>mesh>create>midsurface>
This option will automatically extract the midsurface and assigns the thickness according to it. But it will do auto surface editing after extracting the mid, It may not connect the surfaces as required.
2)Utility menu>Geometry mesh>midsurface thickness
This option will consider the existing elements for assigning the thickness. Here u r allowed to do the surface editing. But the surface which u r meshing should be extracted mid surface of the required Geometry.
>Property on element
>AutoThere are 2 options to do so
>Auto
>Range interval: Allow u to decide the density of the layers in its length
hi
i am novice at hypermesh i am trying to learn how to assign thickness using the utility option but i canot see any change in the thickness of the element .pls let me know if you have any material or help on this i did follow your steps but still i am not getting any thickness
got the solution thanks for posting your solution it helped me in finding mine:)
Hi there, Is that possible to assign a tapering(varying) thickness for a shell element. Thanks in advance
Try this option, Mesh-create-Midsurf mesh, its a automated process manager which will create the mesh and apples the thickness for the elements with respective to geometry thickness. You ca specify the element length, geometry parameters for fillets, hole watchers, etc.
