🎉Community Raffle - Win $25
Join and Win
Monarch Classic Summaries
User: "Janet_21505"
Altair Community Member
Updated by Janet_21505
I would like to add a count in my summary report.  If I add the measure "count" the summary displays "1"s and reports the total count in the subtotal line for the key "Class".  Is it possible to only report the count subtotal and not see the "1"s.  Hiding the count measure removes it from the summary, but I loose the count subtotal.
Janet Grimsley
Janet Grimsley
VP, Business Intelligence
The Fauquier Bank
Warrenton VA
(540) 349-0215
1 - 4 of 41
    User: "Steve_Caiels"
    Altair Employee
    Updated by Steve_Caiels
    Hi Janet,
    From a *visual* perspective, you can change the foreground and background colours to the same value.  They values will still be there, but will not be visible in Monarch or when printed to physical media or PDF.  (By the way, one of my counts is 2!)
    They may or may not be visible in Excel, depending on versions and options.  I think they will always be visible in applications such as Access, MS SQL Server, csv etc.
    To set this up, edit the summary, select the Count measure, then navigate to the "Coloring and Limits" tab.
    Select "Override for selected groups" and choose the correct level.
    Edit the "Normal Values" and choose the same value for Text and Fill.
    Regards,
    Steve.
    Steve Caiels
    Professional Services
    Altair
    Original Message:
    Sent: 07-16-2019 03:38 PM
    Subject: Monarch Classic Summaries
    Janet Grimsley
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "Janet_21505"
    OP
    Hi Janet,
    Regards,
    Steve.
    Steve Caiels
    Altair
    Original Message:
    Janet Grimsley
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    I should have thought of that.......Thanks, Steve!
    Thank you,
    Janet
    ------Original Message------
    Hi Janet,
    Regards,
    Steve.
    Steve Caiels
    Altair
    User: "Mo Abdolrahim"
    Altair Employee
    Updated by Mo Abdolrahim
    Hi Janet,
    The way your summary is configured, you may try changing the count column color to white (see screenshot below, Coloring and limits)
    I had one of your reports and model, and tried it, and it worked.
    Regards
    Mo
    Mahmoud Abdolrahim
    Senior Implementation & Integration Engineer
    Datawatch Corporation
    MA
    (978) 935-3840
    Original Message:
    Janet Grimsley
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    User: "Janet_21505"
    OP
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Janet Grimsley
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Thanks Mo.  This is an easy solution that I should have come up with.
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
    Original Message:
    Sent: 07-17-2019 08:12 AM
    Hi Janet,
    Regards
    Mo
    Mahmoud Abdolrahim
    MA
    (978) 935-3840
    Original Message:
    Janet Grimsley
    Janet Grimsley
    The Fauquier Bank
    Warrenton VA
    (540) 349-0215
