Flat drap export from hyperworks
Alessio
Alessio Altair Community Member
edited June 2021 in Community Q&A
once the various ply(layer) have been obtained from the analysis with hyperworks on composite materials, how can these layers be exported so that they are flat to be cut on a sheet?
Welcome!
Answers
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    Hi,
    if you're using Kinematic Drape tool, you can export the flat shape as an STEP file.
  • Alessio
    edited June 2021
    but if I don't have a flat shape with this method will I export it as if it were a flat shape?
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    sorry..i didn't get you qeustion.
    for draping you start with your mesh of your formed part, and kinematic draping will try to recover the orientaitons, and the flat shape of your part.
    Then, after that, you can see in the screen the 'flat part' in the review tab, and also export it to step file.
  • Alessio
    edited June 2021
    an ok. So when I do the draping of the skins, does it automatically calculate the flat shape of the skin? because I found the various layers with the freeform and layer placement optimizations and now I have to get the flat shapes of those layers ... I use the method you forwarded to me earlier?
  • Adriano_Koga
    Adriano_Koga
    Altair Employee
    edited June 2021
    yes
Welcome!
Welcome!
