Altair RISE
Nominate Yourself Now!
Hypermesh 2021.2 does not recognise names, 2021.1 worked fine
User: "fc"
Altair Community Member
Updated by fc
Hi, on Hypermesh 2021.1 I've created a .tcl script which was working correctly.
I have now updated to 2021.2: under the Optistruct user profile I had to change stuff like the *setvalue <select_type>=<selection> from name to ids otherwise it wouldn't work.
I have now the same problem with these lines under the Abaqus user profile
*createentity sets cardimage="SURFACE_ELEMENT" type=2 name="set1" *clearmark sets 1 *setvalue sets id=17 id={Sets 1} *setvalue sets id=1 name=dist_inf2molla *setvalue sets id=1 STATUS=2 139=3 *createmark elements 1 2 *createmark nodes 1 9-12 *segmentsetaddfaces "dist_inf2molla" 1 1 30 1 1
I get an "specified segment set does not exist" error for the last line since apparently Hypermesh does not want to use names. Of course "Abaqus is a name-based solver which uses a label/string to reference entities" so I cannot find alternatives.
Is this expected behaviour? Is there anything I can do regarding the changes in id synchronization made in the Hypermesh 2021.2 update?
Thanks
1 - 9 of 91
    User: "Subhu"
    Updated by Subhu
    Hi,
    Try this -->> *createentity sets cardimage="SURF" type=2 name="set1"
    User: "fc"
    OP
    Updated by fc
    Thanks for your reply :)
    I have tried what you're suggesting but unfortunately it gives me the same error. Also, I need cardimage to be "surface_element" because I need to export to an abaqus .inp file, though I don't know if in 2021.2 "surf" is the new "surface_element"
    EDIT - I have enabled the script debugger and I've obtained this log (also attached)
    0 0     while executing "*setvalue sets name=inf ids={elems 2}"     (file "D:/Fcaroli/coil working directory/01_00/MacroHM_01_00.tcl" line 87)     invoked from within "source {D:/Fcaroli/coil working directory/01_00/MacroHM_01_00.tcl}"     ("uplevel" body line 1)     invoked from within "# Compiled -- no source code available error "called a copy of a compiled script""     (procedure "::hw::RunTclTkScpt" line 1)     invoked from within "::hw::RunTclTkScpt"     ("eval" body line 1)     invoked from within "# Compiled -- no source code available error "called a copy of a compiled script""     (procedure "::hw::p_TbCmdSelection" line 1)     invoked from within "::hw::p_TbCmdSelection ::hw::RunTclTkScpt runMenu 0"     ("eval" body line 1)     invoked from within "# Compiled -- no source code available error "called a copy of a compiled script""     (procedure "::hwt::ReleaseCanvasButton" line 1)     invoked from within "::hwt::ReleaseCanvasButton 0 ._Tb_Scripting.runMenu.b"     (command bound to event)
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    What is the message in the bottom left corner when you get this error? How do you know the ids in your code since those are hard coded in and not a variable?
    User: "fc"
    OP
    Updated by fc
    Error message is "specified segment set does not exist". I also get "*setvalue: sets with name inf is not a valid entity"
    I know the IDs because the script explicitly changes them to the ones I need (anyway they are visible in the UI)
    I also have the issue that if I execute the exact lines Hypermesh created in command1.tcl when switching user from Optistruct to Abaqus, it will not actually change anything
    Altair Employee
    Looks like you need to use *segmentsetaddshells (or I imagine the *segmentsetaddfaces would work too) not *setvalue.
    User: "fc"
    OP
    Updated by fc
    Thanks for your replies. *setvalue did work on 2021.1. The issue is not *setvalue per se, but rather that Hypermesh does not recognise names, only IDs. I can try to avoid names to some extend but there must be a reason I need to do so on 2021.2.
    I've also tried reinstalling Hyperworks (while having checked the installer md5 checksum), with no luck. "no source code available" can't be right I think
    Altair Employee
    I am able to use names, so it doesn't seem to be specific to names.
    User: "fc"
    OP
    Updated by fc
    I'm saying it's specific to names only from the errors Hypermesh displays. But as you say, I was able to use name too, so I can't find why it does not work with 2021.2. Thanks for your feedback on that
    Names not working might be an issue related to the Abaqus interface not working properly (?) but I don't really know how to deal with that. Maybe there are some settings I need to adjust?
    User: "fc"
    OP
    Updated by fc
    [CORRECT ANSWER]
    Apparently, in 2021.2 the command "*setvalue sets id=xxx name=yyy" does change a set's name in the user interface, but it does NOT change the internal name. In Hypermesh 2021.1 it worked fine
    The solution is to apply the desired name directly with the "*createentity sets cardimage="xxx" type=yyy name="zzz"" command, which successfully modifies both the internal name and the one shown in the UI
    Also, 2021.2 applies Set IDs starting from the latest+1 as 2021.1, but 2021.2 has different ID counts for Sets and  for Set Segments
