🎉Community Raffle - Win $25
Join and Win
I want to create stress in BCs
User: "Karshenas Reza"
Altair Community Member
Updated by Karshenas Reza
hi
I want to create two type of stress on a rotor: shear stress and normal stress. Because the surface is circle, I cant find an easy solution to apply pressures normal and paralle to surface. also can you offer me a methode?
1 - 4 of 41
    User: "Ben Buchanan"
    Altair Employee
    Updated by Ben Buchanan
    You can create normal forces as a pressure.
    You can use a cylindrical coordinate system to define forces in the tangential direction (y-axis).
    You can also create normal forces with the same cylindrical coordinate system (radial, x-axis).
    OP
    thanks for answer. but as pressure it is not possible to use a local coordinate system like cylindrical or spherical. is it? there is no option to choose different local coordinates, but only globale.
    Altair Employee
    Right you would use a pressure to create a normal force or a coordinate system to define normal loads.  The only way I thought of creating parallel surfaces was with a coordinate system.
    OP
    ya, got it, thanks for tips. helped me.
