How can i choose the element size of 3d solid for a topology optimization
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
Please i wonder always how can i choose the element size of a 3d body (60*80*400) for a topology optimization ? ho can i be sure for example that element size =4  is the perfect size of elements or no  ?
Thank you
1 - 5 of 51
    User: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    The choice depends to:
    • Your goal of analysis, your precision
    • Your capacity of computing hardware
    • Your FEM experiences
    Altair Employee
    OP
    For exemple i choose element size = 4 for this solid body
    and i get the result in picture 2  ( with MINDIM=12)
    now how can i say that this element size is suffisant or not ? how can i say it's the right one or not ?
    thank you
    Maybe try with size=3,2,1 and compare all?
    Altair Employee
    OP
    if i will whange the size i will reconnect all the fix bolt (beacause i will loose the ID of élements connected with RBE3 ELEMENTS )
    there is an solution to remesh only the inside of the solidbody without make any difference on the outsides elements connected with other body ?
    Than you
    Altair Employee
    OP
    HI,
    There is no thumb rule for mesh size. You can do a mesh sensitivity analysis to get the right mesh size for your model and use the same for topology optimization.
