BIRD STRIKE ON COMPOSITE FAN BLADE
i'm trying to do analysis of impact in composite fan blade (leading edge in titanium). I use radioss with matcompsh_25 and Propstack_17. When i try to launch the analysis the following errors appear. can you help me resolve them ? Thanks
ERROR ID : 286
** ERROR IN INPUT CONSISTENCY
DESCRIPTION :
QUAD ARE NOT COMPATIBLE WITH N2D3D=0
.. UNITS SYSTEM
.. MATERIALS
ERROR ID : 198
** INPUT ERROR IN MATERIAL LAW 25
DESCRIPTION :
-- MATERIAL ID : 1
-- MATERIAL TITLE : composito carbonio
SIGYT1 IS LESS THAN ZERO
ERROR ID : 30
** ERROR IN COMPOSITE SHELL DEFINITION
DESCRIPTION :
-- PROPERTY ID : 0
-- PROPERTY TITLE :
-- MATERIAL ID : 0
-- MATERIAL TITLE : 0
LAW 0 IS NOT COMPATIBLE WITH THIS PROPERTY
SOLUTION :
COMPATIBILITY WITH MATERIAL LAWS 25, 27, 36, 60 AND USER LAWS
.. 2D SOLID ELEMENTS
.. 3D SHELL ELEMENTS
.. 3D TRIANGULAR SHELL ELEMENTS
.. SPH PARTICLES DEFINITION
.. SUBSETS
.. ELEMENT GROUPS
ERROR ID : 70
** ERROR IN QUAD ELEMENT GROUP
DESCRIPTION :
-- GROUP ID : 3
-- GROUP TITLE : ply3
ELEMENT ID=166 DOES NOT EXIST
hi Prakash, thank for the reply. I assigned at all components his material and property as you can see in the pictures.
I created pstack_17 than i assigned at blade, after that i created ply and laminate. other components are the Leading edge in titanium (matlaw2) and bird (sph).
for the project a learnt the tutorial 'bird strike on wing' .
There are multiple errors,
PLY Card is updated for plies and few components are missing PART card image
Also, I would suggest you create plies with elements instead of shell.
I will share the modified file. Please check the model before you run as I accidentally modified few elements.
HI,
I had a look at your file.
You have provided INIV in Engine but no nodes are provided. Please check this.
Also, please remove rigid from TH/PART as no part image is provided for the same.
From Engine, please remove ANIM/ELEM/FAIL. Some entities are not supported and this may lead to another error.
Hi,
Looks like property and material is not assigned component(s).
Can you please check and update the same if they are not assigned on component?
