🎉Community Raffle - Win $25
Join and Win
Meshing Error - tetramesh
User: "Julian_St"
Altair Community Member
Updated by Julian_St
Hello,
I am working on a wing and want to mesh it, but I get the error message : '2 edges failed nodal setup. Meshing failed.'
There are no T-connections, but I found 424 free edges. What steps do I have to take to get the full mesh?
Regards,
Julian
1 - 1 of 11
    User: "Simon Križnik"
    Updated by Simon Križnik
    Hi,
    2 surfaces failed to mesh in your model. Unmeshed surfaces can be found in the automesh panel (F12)>unmeshed.
    The mesh failed probably due to bad geometry. One option is to perform automatic geometry cleanup Geom>autocleanup, but this option can suppress necessary feature edges. Some edges have to be manually edited with Geom>edge edit>toggle  or (un)suppress (also in quick geometry edit panel F11).
