The problem of static analysis of adhesive problem
User: "mansin"
Altair Community Member
Updated by mansin
Hi, everyone.
     I created a simple model of two rectangular plates connected by adhesives between them. In this model, all degrees of freedom are constrained at one side , the distributed force  is applied on the other side. The property of plates and adhesive are Steel and Epoxy Glue, respectively.
    (1) Why are there great differences between the stress distributions on two plates?  The stress level of the plate with constraints is much higher than the other plate, why?  (Is induced by the clamped constraints?) I think there are also problems with stress concentration and displacement.
    (2) Why is the stress level of adhesive so low?
   Can anyone give me some advises?
   Thanks.
1 - 5 of 51
    User: "Altair Forum User"
    Altair Employee
    Updated by Altair Forum User
    hi mansin,
    There is stress in the second plate also. You can check it by selecting only the second component like shown below.<?xml version="1.0" encoding="UTF-8"?>123.thumb.png.005f56d169b66686e1daf83d4cda646b.png
    Its only because of the scale factor, you are not able to see any stresses in the 2nd plate, while considering both the components.
    Thank you
    User: "mansin"
    OP
    Updated by mansin
    Hi, Premanand Suryavanshi,
    Thank you for your advise. I still have the question: Why are there great differences between the stress distributions on two plates? The stress level of the constrained plate is almost ten times higher than that of the other plate.
    Thanks.
    Altair Employee
    Hi,
    The stress will always be more at the fixed end. Hence, it shows more stress in the top plate.
    Thank you
    Altair Employee
    Hi,
    For a clamped model like this it will always tend to break from the fixed end as all the dof is arrested here. And that's why you're getting high stresses at fixed end.
    User: "Mario_21478"
    Updated by Mario_21478
    Hello,
    It is quit simple. Due to the distance between the two plates, there is a bending moment at the clamped plate (plus axial load).
    In the free plate is only the axial stress. You can check it, it's about 11 MPA (3800N/3500mm*mm=11MPa) nearly constant (global Sigma Y).
    Some general hints to adhesive modelling:
    • Normally you can't use a static solver for thick film bonding, depending on the stiffness of the glue
    • Normally thick film glue has a Poisson ratio near by 0.5 and extremely nonlinear material behavior
    • As example, if you want to glue with Sikaflex, then you have large strains. This isn't included in static linear or quasi static nonlinear. You have to use geometric nonlinear, be sure the solver supports large strains
    • A nonlinear 'standard' elastic plastic material isn't sufficient to describe the material behavior
    • Your maximum displacement is about 15mm, it isn't 'small' in terms of linear static
    • Depending on type of bonding you have to take into account creep and relaxation
    • Depending on load conditions you have to take into account dependence on strain rate effects
    I'm not a expert on this, but be sure it is a quit difficult topic.
    Best Regards,
    Mario
