🎉Community Raffle - Win $25
Join and Win
rbe3 into mpc
User: "arh423"
Altair Community Member
Updated by arh423
Hello,
I want to convert a rbe3 into a mpc to use it in a specific loadstep.
How did I need to set up the mpc to gain a equal behaviour to the rbe3?
Thank you!
1 - 4 of 41
    User: "Dhanasharee Jadhav_21915"
    New Altair Community Member
    Updated by Dhanasharee Jadhav_21915
    Hi,
    Please tell me which specific Load step , because it will not convert only for load step, it will change at model level.
    Regards,
    Dhanasharee Jadhav
    User: "arh423"
    OP
    Updated by arh423
    Thank you for your answer!
    But I am not sure what you want me to tell you.
    I wanted to put a load on a rbe3 element and distribut it in a set of nodes.
    I an other (sequential) loadstep I wanted to put an other load on rbe3, but some independent nodes of the two rbe3 are equal.
    And this results in error message.
    But I cannot avoid to use some nodes from the first loadstep and first rbe3 in the second loadstep and second rbe3.
    I thought I could solve this through using an MPC instead of an rbe3 because I can define the MPC specific to an loadstep.
    Is this the right way?
    If yes, I am not sure which configuration I need to give the MPC when creating in Hypermesh panel.
    Thank you!
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    what is the error message you're getting?
    It should be possible to use 2 different RBE3s, i believe, even sharing some of the indep nodes.
    User: "arh423"
    OP
    Updated by arh423
    It just worked with the rbe!
    Must be another error in the previous model.
    Thank you!
