meshing in batch mode
Altair Community Member
Updated by Enrico_20294
Hi All,
I have to run in batch mode a tcl file, in which a meshing process is recorded.
Is there a guide or some tutorials?
The tcl is perfectly working if i run it from Hypermesh, but it doesn't if I use hmbatch.exe
Thanks,
Enrico
1 - 3 of
31
Hi All,
Thanks,
Enrico
Hmbatch.exe will call hmopengl.exe
So you can call hmopengl.exe directly and hide its GUI by prepending this line:
wm withdraw .
And append 'exit'
Hello @Enrico
In most cases you have to load the template file, instead of select UserProfile.
Please try to add the this line for beginning of your script.
*templatefileset [file join [hm_info -appinfo ALTAIR_HOME] templates feoutput optistruct optistruct]
Note: If you are not using OptiStruct profile, please change to your user-profile.
Thanks,
Imoto
