🎉Community Raffle - Win $25
Join and Win
Jacobian check using macro
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi all
I am very new to tcl and macro making and was trying to create a macro for checking the jacobian.
Using the help file from hypermesh desktop reference guide this is what i did:
(Documents) 72 % *createmark elems 1 'displayed'
(Documents) 72 % *createmark elems 2
(Documents) 74 % *elementtestjacobian (elements,1,0.7,2,2,0,'jacobain')
this gives an error of 'unknown entity type found'.
so i tried doing this:
(Documents) 73 % *elementtestjacobian (elements, $1 ,0.7, $2 ,2,0,'jacobain')
but this gave an error of 'can't read 2 no such variable found'.
I have done exactly what was mentioned in help file then why I am getting error?
<?xml version="1.0" encoding="UTF-8"?>post-33620-0-24254900-1430727743_thumb.p
1 - 6 of 61
    Altair Employee
    OP
    Hi Bavana,
    Do you see 'xxx elements have selected' when you place the elements on the mark 1?
    Looks like the elements are not selected from the display.
    Altair Employee
    OP
    It works no problem for me.
    Here's my TCL script :
    *createmark elements 1 'displayed'
    *createmark elements 2
    *elementtestjacobian elements 1 0.7 2 2 1 '2D Element Jacobian'
    And I got the picture:
    <?xml version="1.0" encoding="UTF-8"?>post-889-0-75396200-1430732607_thumb.png
    Altair Employee
    OP
    Dear sir
    Thanks for the script you gave me. I guess the entire difference was of the brackets I was using which you didn't use.
    The script is working perfect now.
    Thanks again.
    Altair Employee
    OP
    Hi,
       How would I retrieve all the values in the check elems (warpage,aspect,skew, etc) in a variable
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    Hi
    there is not direct command to return those values
    you can make a tcl script to append each value into the variable
    to retrieve each value, using hm_getentityvalue
    or you can make a template to write them to a file, and read it into the variable
    Altair Employee
    OP
     Hi,
       You can use [hm_get2delemchecktestval warpage2d] to get the values.
