Why solidworks file can't be shown in hyperworks?
Hi all,
I encountered the problem that the status shows that the Solidworks file is ready to be imported in HyperWorks ( 2017 student edition), but I don't see my model.What should I do?
Thanks,
Kewei
When you import and you see nothing it means that importation was failed.
HI Kewei,
Can you export in STEP or IGES format from SolidWorks and try importing the same in HyperMesh?.
Meanwhile, is it a SolidWorks assembly file (*.sldasm)?.
Hi George,
I also use STEP and IGES format, but same thing happened, and I still saw nothing. The file is the part, not assembly file.
Thanks,
Kewei
Yeah, or nothing is in his *.sldprt file
Hi tinh,
I can see the part in SolidWorks.
Thanks,
Kewei
Hi Q.Nguyen-Dai,
I also think so. Actually, my document is converted from another format, and the file can be seen in Solidworks, but can't be found in Hypermesh. Do you have some tips to solve this problem?
Thanks,
Kewei
Hi Kewei,
Can you please share the file so that we can review the same.
Hi Kewei,
Hi George,
I don't have the copyright of the file.I will do it when I get permitted.
Thanks,
Kewei
How many MB is the Step file?
Sometimes hm hides geometry data
After imported, can you try exporting geometry as parasolid format then import it again
Hi tinh,
The file is over 180MB. I think it is too large.
Thanks,
Kewei
Just sharing some relevant information on import.please find attached file for your reference.
HI Kewei,
