creating mesh between 2 mesh components using tcl script
Pandurang
Pandurang Altair Community Member
edited October 2020 in Community Q&A
Hi all,
I have 2 mesh components..yellow and green
considering yellow comp size...giving some tolerance of at least 2 elements size of green one...want to delete some portion from green as shown...
then create mesh between these two comp...shape can be tri or quad or mixed.
This is shell mesh...
element size of both are different...
no surface available for this 2
I want to automate these things...
1 .  Delete some portion from green...considering size of yellow
 2.  Create mesh between yellow and green keeping connectivity in mind..
please help me out...
if any one have any idea...
Thanks & Regards,
PD
Welcome!
Answers
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited February 2018
    That takes 5' to do in interactive session Hypmermesh.
    Why you need script for this?
  • Pandurang
    Hi,
    Actually i am writing script to create weld between 2 comps. so as per requirement there should be quad elements around weld...so here i m creating weld with quad around it.
    now i want to connect these quad with green comp mesh( this mesh could  be tri or quad or mixed) by deleting some portion from it..
    how can i do that manually.
    Please can u give me steps for this...
    i will get some idea...
    Thanks
    PD
  • QuyNguyenDai
    Share your HM model?
  • Pandurang
    i can't share...against  company policy:(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
  • QuyNguyenDai
    Hi,
    In general, if you don't know how to do that manually, you CAN not write your script.
  • Pandurang
    Yes
    you are absolutely right...
    What should i do now??
    Thanks & Regards,
    PD
  • tinh
    tinh Altair Community Member
    Hi,
    Thanks
    PD
    Many types of weld can be done by hm connector. Don't you use it instead of writing it your self?
  • Pandurang
    Hi Tinh,
    want to connect tetra meshed and shell meshed(could be tri or quad) comps with quad mesh.
     if tri on shell meshed comps ..i have to delete them at vicinity of weld...create quad at deleted portion....then have to renumber these one near by layer of quad at weld in series...and also nodes on weld....
    things i automated till now as per my logic:
    1. projected duplicate nodes from tetra meshed comp on shell meshed...perpendecular
    2. then by drag->nodes planer to shell meshed comps... consider i created yellow meshed(ref attachment)
    now i want to delete some portion of shell meshed comps( green in attachment)
    then connect yellow with green......
    manually this takes much time to work out...
    so want to automate this...
    Regards,
    PD
  • QuyNguyenDai
    Yes
    Thanks & Regards,
    PD
    https://www2.gdtech.eu/wp/2018/02/fill-gap-two-shell-meshes/
  • Pandurang
    Hi,
    I went through that link but i have query....
    1. no lines in model so how can i create surface by Lines as shown in model...
    2. do i have to create lines as well for this or any other option??
    3. how to ensure same node on existing meshes
    all other things i understood......
    Regards,
    PD
  • QuyNguyenDai
    Of course, you have to create lines before making surface.
  • Pandurang
    ok
    Thank you:)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
  • Pandurang
    Tinh and Dai,
    is there any way to automate this? ----->>  https://www2.gdtech.eu/wp/2018/02/fill-gap-two-shell-meshes/
    Regards,
    PD
  • tinh
    edited March 2018
    Yes, certainly
    But it's very time consuming
  • Pandurang
    edited March 2018
    Yes, certainly
    Hi Tinh
    Please give some direction...so that i can work on that
    Regards,
    PD
  • tinh
    edited March 2018
    Hi, try this work
    1) select elems on the yellow patch
    2) find free edges (or loop) of (1)
    3) get nodes list of loop (2) with order , we will use 2d>ruled command to create mesh, so nodes must be input with correct order
    4) get loops of green comp
    5) search for the closest loop in (4), means the inside loop closed to yellow patch
    6) get nodes list of loop (5) with order
    7) first node of nodes list (3) must be closed to first node of nodes list (6), if not -> ruled mesh may be failed
    8) search the closest node in nodes list (6) to the first node of (3), turn around order of nodes in list (6) to obey (7)
    9) make ruled mesh
    10) equivalence the created mesh
  • Pandurang
    edited March 2018
    Hi, try this work
    9) make ruled mesh
    thanks for reply.
    3.  how to get nodelist in order?
    8. ??
    also please suggest some API...
    Regards,
    PD
  • tinh
    edited March 2018
  • Pandurang
    edited March 2018
  • Pandurang
    edited March 2018
    Hi Tinh,
    it worked....but still getting some gap...
    see attachment...
    any workaround.
    regards,
    PD
  • tinh
    edited March 2018
    Please make ruled mesh for remained gap, 2 node lists include first and end nodes of (3) and (6)
  • Pandurang
    edited March 2018
    Yes I have done that...
    I have one query ...
    When i find loops...I get ordered list
    But if I find edges...I didn't get same
    Why so?
    Thanks once again..
    Regards
    PD
  • tinh
    edited March 2018
    :rolleyes:I don't know such detail, but loops are very different from edges, in your simple case above, they look similar
  • sanket_patil
    sanket_patil Altair Community Member
    edited February 2019
    @tinh @Pandurang How to search closet node ?
    Hi, try this work
    9) make ruled mesh
  • tinh
    Hi
    Use hm_getclosestnode
  • sanket_patil
    @tinh Hi,
    I tried but im not able to search it. will you please tell me with example that how to search it in loop?
    Thanks,
    Sanket
  • tinh
    How did you try it?
  • sanket_patil
    @tinh
    I executed first 4 steps correctly. Now i have nodes of free edges of two different components. After that i m confused now how to match closest nodes of two components.
    Regards,
    Sanket
  • tinh
    Or try hm_measureshortestdistance?
Welcome!
Welcome!
