How to un-merge nodes
Altair Community Member
Updated by hiranwale_bharat
Hello,
I have created a solid mesh with connectivity of nodes between two components.
Somehow I want to maintain connectivity at specific edges only and not the entire surface of the solid.
So how can I break this connectivity. ( I want the nodes of the two comp.s to be close as possible, but not equivalenced)
Regards,
Bharat
1 - 2 of
21
OPUpdated by hiranwale_bharat
Hello George,
Thanks for the helpful reply.
Regards,
Bharat
Hi Bharat,
Use the Detach panel (2D > Detach) to detach elements from the surrounding structure. You can detach elements from a portion of your model so that it can be translated or moved, or you can offset the new nodes by a specified value.
Please go through the Detach Panel in Help Menu.
