Altair RISE
Nominate Yourself Now!
unusual issue by running HW and License Problem
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello all,
at first sorry for my poor englich.
i downloaded HW14.0 Student- Edition to run motionview and motionsolve, also ich got a node locked license for Student Edition.  i installed HW14.0 Stu-Edition successfully and placed it in the security folder within the installation folder. everything is ok.
Then i ran HW14, it came a application problem
Details
list element in quotes followed by 'nur' instead of space
    while executing
'llength $pairs'
    (procedure '::msgcat::mcmset' line 4)
    invoked from within
'::msgcat::mcmset de {
        'Rigid Body on Lines'                     'Starrkörper auf Linien'
        'Rigid Body on Surfaces'                  'S...'
    (in namespace eval '::b3d' script line 205)
    invoked from within
'namespace eval ::b3d {
        'Dimension Mode'                          'Vermessungsmodus'
        'Material Database'     ...'
    (file 'F:/Software/Altair/14.0-edu/hm/scripts/BasicFEA/languages/de.msg' line 2)
    invoked from within
'::source -encoding utf-8 F:/Software/Altair/14.0-edu/hm/scripts/BasicFEA/languages/de.msg'
    ('uplevel' body line 1)
    invoked from within
'uplevel 1
  1. '
        (procedure '::msgcat::mcload' line 10)
        invoked from within
    '::msgcat::mcload $msg_directory'
        (procedure '::b3d::L10n::SetLocale' line 14)
        invoked from within
    '::b3d::L10n::SetLocale '''
        (in namespace eval '::' script line 4)
        invoked from within
    '# Compiled -- no source code available
    error 'called a copy of a compiled script''
        invoked from within
    'tbcload::bceval {
    TclPro ByteCode 2 0 1.7 8.5
    14 0 132 24 2 0 84 1 4 14 14 -1 -1
    132
    f!!!!#-<<!+f+pv+K&s!*V!S7&-<<!)9N<!3fAs!5v!!!C!!!!gF#!!)`vpv1l8X!...'
        (file 'F:/Software/Altair/14.0-edu/hm/scripts/BasicFEA/main.tbc' line 14)
        invoked from within
    'source $rootname.tbc'
        (in namespace eval '::UserProfiles::BasicFEA' script line 7)
        invoked from within
        (procedure '::hwt::SourceFile' line 1)
        invoked from within
    '::hwt::SourceFile $path3/BasicFEA/main.tcl'
        (procedure '::UserProfiles::BasicFEA::PanelProc' line 47)
        invoked from within
then i click OK and chose die Motionview-icon,  however i find that Motionview and Motionsolve can run perfect. i have tried many times wenn i run HW in a month, this issue occurred  everytime. because i can run Motionview and Motionsolve so i forget it and let it
These days i learn co-simulation using simulink and motionsolve, i want to use a xml file that i can put it into simulink-S funktion. so at first i run a simulation with my own model and generate a xml file. then i try to run it by motionsolve,like tutorial MV 7002.  unfortunately, it occurred another issue
so i dont unterstand what is happend, accualy before this happend, i have puted some xml files into simulink-S funktion but simulink always can`t run a cosimulation because of a error' input xml file is not accessible', through i have set environment variable and matlab path. so i guess ,this licence issue is a big unusual problem against my cosimulation-work using simulink and run xml file using motionsolve
today i have read  basic licence troubleshooting and used the command to get my physical adress, i use a pc with system Win10 64bit
C:\Users\Kan>ipconfig/all
Windows-IP-Konfiguration
   Hostname  . . . . . . . . . . . . : Zack
   Primäres DNS-Suffix . . . . . . . :
   Knotentyp . . . . . . . . . . . . : Hybrid
   IP-Routing aktiviert  . . . . . . : Nein
   WINS-Proxy aktiviert  . . . . . . : Nein
Ethernet-Adapter LAN-Verbindung:
   Verbindungsspezifisches DNS-Suffix:
   Beschreibung. . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physische Adresse . . . . . . . . : 00-08-02-E6-1D-FC
   DHCP aktiviert. . . . . . . . . . : Ja
   Autokonfiguration aktiviert . . . : Ja
   IPv6-Adresse. . . . . . . . . . . : 2a02:908:4e0:fda0:208:2ff:fee6:1dfc(Bevorzugt)
   Lease erhalten. . . . . . . . . . : Donnerstag, 28. Juli 2016 23:20:25
   Lease läuft ab. . . . . . . . . . : Freitag, 29. Juli 2016 00:24:25
   IPv6-Adresse. . . . . . . . . . . : 2a02:908:4e0:fda0:757d:9711:dfdf:ca51(Bevorzugt)
   Temporäre IPv6-Adresse. . . . . . : 2a02:908:4e0:fda0:bcb6:a5ab:c610:414a(Bevorzugt)
   Verbindungslokale IPv6-Adresse  . : fe80::757d:9711:dfdf:ca51%5(Bevorzugt)
   IPv4-Adresse  . . . . . . . . . . : 192.168.0.14(Bevorzugt)
   Subnetzmaske  . . . . . . . . . . : 255.255.255.0
   Lease läuft ab. . . . . . . . . . : Freitag, 29. Juli 2016 23:20:23
   Standardgateway . . . . . . . . . : fe80::ce35:40ff:fe29:e1a3%5
                                       192.168.0.1
   DHCP-Server . . . . . . . . . . . : 192.168.0.1
   DHCPv6-IAID . . . . . . . . . . . : 234890269
   DHCPv6-Client-DUID. . . . . . . . : 00-01-00-01-18-3B-88-50-00-08-02-E6-1D-FC
   DNS-Server  . . . . . . . . . . . : 2a02:908:2:a::1
                                       2a02:908:2:b::1
                                       192.168.0.1
                                       192.168.0.2
   NetBIOS über TCP/IP . . . . . . . : Aktiviert
Tunneladapter isatap.{523E55D6-2B14-4E33-A44F-D62361A67184}:
   Medienstatus. . . . . . . . . . . : Medium getrennt
   Beschreibung. . . . . . . . . . . : Microsoft ISATAP Adapter
   Physische Adresse . . . . . . . . : 00-00-00-00-00-00-00-E0
   DHCP aktiviert. . . . . . . . . . : Nein
Tunneladapter LAN-Verbindung* 2:
   Beschreibung. . . . . . . . . . . : Microsoft Teredo Tunneling Adapter
   IPv6-Adresse. . . . . . . . . . . : 2001:0:5ef5:79fb:ce7:a7a:dae7:63be(Bevorzugt)
   Verbindungslokale IPv6-Adresse  . : fe80::ce7:a7a:dae7:63be%6(Bevorzugt)
   DHCPv6-IAID . . . . . . . . . . . : 100663296
   NetBIOS über TCP/IP . . . . . . . : Deaktiviert
C:\Users\Kan>getmac
Physisch. Adresse   Transportname
00-08-02-E6-1D-FC   Nicht zutreffend
 here the licence info
so i find that licence is ok, version=14 and ETHERNET 000802E61DFC are also OK..but the MAC adress is 'not applicable' (german:nicht zutreffend) by using getmac
who can tell me, what can i do to fix these, i need your help....
thank you
1 - 3 of 31
    User: "Rahul_P1"
    Altair Employee
    Updated by Rahul_P1
    This may occur if there are quotes in materials names or other collector names. Remove quotes in material names etc and let us know if it helped
    User: "Jan Grasmannsdorf_20379"
    New Altair Community Member
    Updated by Jan Grasmannsdorf_20379
    Hello,
    the first issue is related to starting HyperWorks with the BASIC FEA User Profile. This will lead to the error message as you deacribed. To avoid, please select a different User Profile (e.g. OptiStruct) and then close and restart the HyperWorks Student Edition.
    The second error is a license error, probably due to the fact that the HyperWorks Student Edition does not support Co-Simulation with Simulink yet. You would need to use the full license of your university and a full installation of HyperWorks 14 to run the Co-Simulation. Please contact your university advisor or us in order to get access to a full license of HyperWorks.
    Jan
    Altair Employee
    OP
    Hello,
    Jan
    Thank you Jan
    I have used the full license to run HW14.0 in my uni with MV7002-Cosimulation with Simulink. But the save error appeared everytime..
    See hier
    i have added the xml full path..but it didn't help
    have you any idee? thanks a lot!
