Post processing
Hi,
I could run the simulation in Radioss and it showed 'processs successful' but with some errrors. But the output file is not being created at all. I tried different methods like creating an output file for hyperview and for hypermesh but no result. Could this be due the errors? Expecting suggestions...
1 - 1 of
11
Most probably you don't get any results due to the errors you mentioned. I know RADIOSS has a very comprehensive way to present errors in the output files (in contrast to NASTRAN...) so the information you get from there will guide you to solve any mistakes in the model or its boundary conditions. What type of analysis are you trying to do? If you're using RADIOSS bulk I might be able to help. In the meantime check the consistency of your mesh and its quality (node equivalence, duplicate nodes/elements, aspect ratio, jacobian etc.) and your model BCs. If you were using NASTRAN as solver I would recommend (but ONLY for error checking!) to use PARAM,BAILOUT,YES to solve a problem even with errors, but unfortunately RADIOSS doesn't support this parameter.
