Issues with 3D Meshing
Hi,
I realize that this topic may make me seem like a noob with HyperMesh but yes that's pretty much what I am at this point.
I'm trying to use 2D surface meshing and 3D mapping of the mesh on a geometry.
I've been able to get fairly far but having issues getting some of the solid parts to become mappable.
Moreover, there are a lot of shared edges which I can't seem to surpresss (image below) and I'm not sure how to surpress them. I am hoping to do this to take advantage of hyperworks far superior meshing abilities.
My goal is to run a loading analysis followed by topology optimization of the geometry.
Any help would be appreciated!
Attached is the hm file.
@Rahul R - I am still getting used to hyperworks but I'll try 3d tetra meshing. Does this require mappable volumes?
Okay so automeshing works fine, and so does the analysis and optimization (to an extent) on an automeshed geometry.
The issue is that when I start splitting up the geometry (as in my original post), and try to add relevant loads and boundary conditions that way, the solver exits with a series of error messages as follows:
'CQUAD4 2205 0 4417 4418 4419 4420' This line was interpreted as: 451331:CQUAD4, 2205, 0, 4417, 4418, 4419, 4420 *** ERROR # 1000 *** in the input data: Incorrect data in field # 3. Expected INT > 0 or blank, found INTEGER (0).
I am suspecting this error is caused by a property not being assigned to the elements created from solid mapping. The solid map component collector has the property assigned but I am still getting this error.
Enter tab 'Mask' on data browser
click on Isolate column '1' of Elements>2D
delete all 2D elements because your model is 3D
Again to mapping the tube with block. If you cannot find mappable solution,
can we separate the tube from block while meshing? then we will connect them by something like RBE3 / contact ???
I had already separated the tube from the block using solid edit. I later just deleted the rod because it wasn't really helping the optimization (and I didn't want it removing material from the rod).
I tried deleting the 2D mesh and hiding the original geometry, but was still having issues getting the properties to 'attach' to the solid-map mesh properly
I decided to go with an automatically generated tetramesh for now, as I could't get the mapped mesh to work as intended.
Currently trying to understand the parameters of the opimization panel as I need them :P.
Thanks for all the tips!
Maybe share your HM model?
