runFEKO - ERROR 3623: FEKO caught an illegal instruction, code is not running on this processor
My processors are dual Xeon E5-2540 v3 (2 processors),I try to run FEKO at local machine.
In component launch options -> FEKO tag, if I set processers more than 1 (default is 16), output tag which in window executing runfeko show:
Creating file startup_fr_1_ada_1.fek, please be patient ...
File startup_fr_1_ada_1.fek has been created:
58 metallic triangles in free space
FEKO caught signal 4 (PID 5152)
The following message from the master process (MYID= 0):
The FEKO model that I used is “startup.fek”.
Selection 'Use shared memory / OpenMP .........' is useless.
Thanks
