🎉Community Raffle - Win $25
Join and Win
Merge Duplicated Meshes with Pressure Loads
DR31415User: "DR31415"
Altair Community Member
Updated by DR31415
Hi,
I am looking for a solution or an alternative solution to my question.
Question:
I have two identical meshes in my model. Each mesh has a set of pressure loads associated with it.
Mesh 1 ---> Pressure load Set 1
Mesh 2 ---> Pressure load Set 2
Load Set 1 and Load Set 2 have pressure applied in the same location but different magnitude.
I would like to keep one Mesh, e.g. Mesh 1 and have Load Set 1 and Load Set 2 applied to Mesh 1 only.
Is there an easy way to do this HM?
I have tried 'Tool --> edges --> equivalence' and 'Tool --> faces --> equivalence' approaches which merge the nodes to one set but not the elements. So that Mesh 1 is still tied to Load
Set 1 and Mesh 2 is still tied to Load Set 2. Perhaps I am not doing the process correctly, but any guidance would be greatly appreciated.
1 - 3 of 31
