🎉Community Raffle - Win $25
Join and Win
Python Bridge - 2D Lists from Python cannot be read back into OML
In the attached script, one can see that 1D lists such as list1=[1,2,3] can be imported in OML without a hassle.
Whereas when I try to import a list2=[(1,1),(2,2),(3,3)], I receive an error message in OML saying that list2 does not exist.
I use the command getpythonvar().
Am I missing something?
I have attached a file that can be used to reproduce my error message.
I am using Compose 2019.3
Thanks a bunch,
Deb
1 - 6 of 61
    L MorettiUser: "L Moretti"
    New Altair Community Member
    Updated by L Moretti
    Hello Debdatta Sen,
    I think the issue is in what is contained in the list: tuples.
    Tuples are not supported. You can look at the supported Python DataTypes in the help page.
    Here a screenshot:
    Regards,
    Lorenzo
    robertavarelaUser: "robertavarela"
    Updated by robertavarela
    What you can do is to convert your tuple into list. An example:
    t = ('my', 'name', 'is', 'mr', 'tuple')
    l = list(t)
    And then use getpythonvar to retrieve the variable.
    Regards,
    Roberta
    Hello Debdatta Sen,
    Here a screenshot:
    Regards,
    Lorenzo
    Thanks for the quick response!!
    Are there any plans to support them in the future?
    l = list(t)
    Regards,
    Roberta
    Thanks, for the tip!
    But I think it works for 1D lists again isn't it?
    I have a tuple again as soon as I have a single 2D element as in t = [('my', 'name'), 'is', 'mr', 'tuple']
    In this case, you'd need to use list function again in those tuples inside the list:
    l[0] = list(l[0])
    Which would generate this variable:
    [['my', 'name'], 'is', 'mr', 'tuple']
    With getpythonvar, the output would be a cell within a cell:
    Regards,
    Roberta
    Workaround:
    In Python:
         list3 = [list(child) for child in list2]
    In  OML:
       getpythonvar('list3')
