🎉Community Raffle - Win $25
Join and Win
solid mesh
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
How to mesh a spherical solid? please help... thank you
1 - 4 of 41
    Altair Employee
    OP
    Hello,
    If you have a sphere primitive, then the best way is to cut the sphere into 4 parts.
    First step: solid edit->trim with line->bounding lines->extend trimmer
    Second step: solid edit->trim with plane->with plane (choose the plane, e.g. x->0,0,0)
    Normally i'm meshing one of the inside surfaces (quarter) with the 2D automesher. Then i'm spinning the mesh by 360 deg and e.g. 24 steps.
    Regards
    Mario
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi,
    You can mesh a sphere from a cube (hex8 element),
    just split it and then project outer nodes on sphere bound surfs, repeat these two steps until you get enough fine mesh
    To split a hexa you enter split element (Shift+F6)/solid element/split into hexas
    Altair Employee
    OP
    Thanks a lot....
    I imported an iges model into Hypermesh.... I'm not able to mesh it.... can i be able to post the file..... please kindly help...
    Thanks and regards,
    Padmini
    User: "tinh"
    Updated by tinh
    Hi,
    Save below data as a *.fem file and import it (Optistruct template)
    You will understand and be able to mesh a sphere:
    GRID 1 0.0 0.0 0.0
    GRID 2 10.0 0.0 0.0
    GRID 3 10.0 10.0 0.0
    GRID 4 0.0 10.0 0.0
    GRID 5 0.0 0.0 10.0
    GRID 6 10.0 0.0 10.0
    GRID 7 10.0 10.0 10.0
    GRID 8 1.4667-49.9998539.999853
    GRID 9 1.4667-420.000151.4667-4
    GRID 10 9.99985320.000151.4667-4
    GRID 11 9.99985329.999851.4667-4
    GRID 12 1.4667-429.999851.4667-4
    GRID 13 1.4667-420.000159.999853
    GRID 14 9.99985320.000159.999853
    GRID 15 9.99985329.999859.999853
    GRID 16 1.4667-429.999859.999853
    GRID 19 5.0 18.87646-1.12354
    GRID 20 -1.1235425.0 -1.12354
    GRID 21 -1.1235418.876465.0
    GRID 22 11.1235425.0 -1.12354
    GRID 23 11.1235418.876465.0
    GRID 24 5.0 31.12354-1.12354
    GRID 25 11.1235431.123545.0
    GRID 26 -1.1235431.123545.0
    GRID 27 5.0 18.8764611.12354
    GRID 28 -1.1235425.0 11.12354
    GRID 29 11.1235425.0 11.12354
    GRID 30 5.0 31.1235411.12354
    GRID 31 5.0 25.0 -3.66
    GRID 32 5.0 16.34 5.0
    GRID 33 -3.66 25.0 5.0
    GRID 34 13.66 25.0 5.0
    GRID 35 5.0 33.66 5.0
    GRID 36 5.0 25.0 13.66
    GRID 37 5.0 25.0 5.0
    CHEXA 1 0 1 2 3 4 5 6
    + 7 8
    CHEXA 3 0 9 19 31 20 21 32
    + 37 33
    CHEXA 4 0 19 10 22 31 32 23
    + 34 37
    CHEXA 5 0 20 31 24 12 33 37
    + 35 26
    CHEXA 6 0 31 22 11 24 37 34
    + 25 35
    CHEXA 7 0 21 32 37 33 13 27
    + 36 28
    CHEXA 8 0 32 23 34 37 27 14
    + 29 36
    CHEXA 9 0 33 37 35 26 28 36
    + 30 16
    CHEXA 10 0 37 34 25 35 36 29
    + 15 30
