How to mesh a spherical solid? please help... thank you
If you have a sphere primitive, then the best way is to cut the sphere into 4 parts.
First step: solid edit->trim with line->bounding lines->extend trimmer
Second step: solid edit->trim with plane->with plane (choose the plane, e.g. x->0,0,0)
Normally i'm meshing one of the inside surfaces (quarter) with the 2D automesher. Then i'm spinning the mesh by 360 deg and e.g. 24 steps.
Regards
Mario
You can mesh a sphere from a cube (hex8 element),
just split it and then project outer nodes on sphere bound surfs, repeat these two steps until you get enough fine mesh
To split a hexa you enter split element (Shift+F6)/solid element/split into hexas
Thanks a lot....
I imported an iges model into Hypermesh.... I'm not able to mesh it.... can i be able to post the file..... please kindly help...
Thanks and regards,
Padmini
Save below data as a *.fem file and import it (Optistruct template)
You will understand and be able to mesh a sphere:
GRID 1 0.0 0.0 0.0
GRID 2 10.0 0.0 0.0
GRID 3 10.0 10.0 0.0
GRID 4 0.0 10.0 0.0
GRID 5 0.0 0.0 10.0
GRID 6 10.0 0.0 10.0
GRID 7 10.0 10.0 10.0
GRID 8 1.4667-49.9998539.999853
GRID 9 1.4667-420.000151.4667-4
GRID 10 9.99985320.000151.4667-4
GRID 11 9.99985329.999851.4667-4
GRID 12 1.4667-429.999851.4667-4
GRID 13 1.4667-420.000159.999853
GRID 14 9.99985320.000159.999853
GRID 15 9.99985329.999859.999853
GRID 16 1.4667-429.999859.999853
GRID 19 5.0 18.87646-1.12354
GRID 20 -1.1235425.0 -1.12354
GRID 21 -1.1235418.876465.0
GRID 22 11.1235425.0 -1.12354
GRID 23 11.1235418.876465.0
GRID 24 5.0 31.12354-1.12354
GRID 25 11.1235431.123545.0
GRID 26 -1.1235431.123545.0
GRID 27 5.0 18.8764611.12354
GRID 28 -1.1235425.0 11.12354
GRID 29 11.1235425.0 11.12354
GRID 30 5.0 31.1235411.12354
GRID 31 5.0 25.0 -3.66
GRID 32 5.0 16.34 5.0
GRID 33 -3.66 25.0 5.0
GRID 34 13.66 25.0 5.0
GRID 35 5.0 33.66 5.0
GRID 36 5.0 25.0 13.66
GRID 37 5.0 25.0 5.0
CHEXA 1 0 1 2 3 4 5 6
+ 7 8
CHEXA 3 0 9 19 31 20 21 32
+ 37 33
CHEXA 4 0 19 10 22 31 32 23
+ 34 37
CHEXA 5 0 20 31 24 12 33 37
+ 35 26
CHEXA 6 0 31 22 11 24 37 34
+ 25 35
CHEXA 7 0 21 32 37 33 13 27
+ 36 28
CHEXA 8 0 32 23 34 37 27 14
+ 29 36
CHEXA 9 0 33 37 35 26 28 36
+ 30 16
CHEXA 10 0 37 34 25 35 36 29
+ 15 30
