🎉Community Raffle - Win $25
Join and Win
Getting material data by id
vreddyUser: "vreddy"
Altair Community Member
Updated by vreddy
set MatE [hm_getentityvalue mats MATERIALID \$E 0 -byid]
In nastran its returning value but in abaqus and radioss its returning zero
1 - 4 of 41
    QuyNguyenDaiUser: "QuyNguyenDai"
    Updated by QuyNguyenDai
    For Abaqus, try:
     hm_getvalue mats id=<MAT_ID> dataname=Young
    For 'Radioss 2017', try:
     hm_getvalue mats id=<MAT_ID> dataname=MAT_E
    timonqUser: "timonq"
    Updated by timonq
    Hello, how to obtain RHO and NU? When I tried to use hm_getentityvalue mats MATERIALID \$E NU 0 -byid I got 0 :(/emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' /> the same for RHO
    Hello  @vreddy @timonq
    Whatever the solver profile, manually change the material data value in hypermesh, and read the command.tcl file.
    Suppose you have changed the density (rho), you will notice the following reflected in your command file: (hypermesh 2017. In older versions, you can find it in 'attributeupdatedouble')
    *setvalue mats id=41 STATUS=2 183={8.77e-009}
    which means '183' is the parameter code. Since you have the attribute dataname now, you can query it in your script like so:
    hm_getvalue mats id=41 dataname=183
    This will return the rho (density) value currently assigned to the field!
