Hi
it is an analysis with OptiStruct
You need to set ASSIGN cards to your OS model, and run 'transient analysis' for the data generation.
Hope this helps
Regards
Hi Rogerio,
Can you please tell me the procedure to make a residual run from start? If i have both the .mrf file & .h3d file, then how to start with ASSIGN control card. I mean how to use it in residual run. Or if you can please share any screenshot of model in which you have used it.
Hi Rogerio,
Hi
Please refer to this documentation:
Regards
Hi
Regards
Hi
I added here an example, based on the documentation information.
I Hope it helps.
Regerda
Hi
Hope this helps
Regards
