I am having problems in understanding how to make a residual run in hypermesh. I have shared the screenshot. PFA
Hi
it is an analysis with OptiStruct
You need to set ASSIGN cards to your OS model, and run 'transient analysis' for the data generation.
Hope this helps
Regards
Hi it is an analysis with OptiStruct You need to set ASSIGN cards to your OS model, and run 'transient analysis' for the data generation. Hope this helps Regards
Hi Rogerio,
Can you please tell me the procedure to make a residual run from start? If i have both the .mrf file & .h3d file, then how to start with ASSIGN control card. I mean how to use it in residual run. Or if you can please share any screenshot of model in which you have used it.
Hi Rogerio, Can you please tell me the procedure to make a residual run from start? If i have both the .mrf file & .h3d file, then how to start with ASSIGN control card. I mean how to use it in residual run. Or if you can please share any screenshot of model in which you have used it.
Please refer to this documentation:
https://2020.help.altair.com/2020.1/hwsolvers/os/topics/solvers/os/flexible_body_generation_intro_r.htm#flexible_body_generation_intro_r
Hi Please refer to this documentation: https://2020.help.altair.com/2020.1/hwsolvers/os/topics/solvers/os/flexible_body_generation_intro_r.htm#flexible_body_generation_intro_r Regards
I added here an example, based on the documentation information.
I Hope it helps.
Regerda
