🎉Community Raffle - Win $25
Join and Win
TCL SCRIPT
User: "Amith Anoop Kumar"
Altair Community Member
Updated by Amith Anoop Kumar
What is the command to show which elements belong to which component
1 - 5 of 51
    User: "Adriano Koga_20259"
    New Altair Community Member
    Accepted Answer
    Updated by Adriano Koga_20259
    for retrieving a list of elements contained into a component, you could use something like that:
    set comp_name "something"  ; #assign some name to a component
    *createmark elems 1 "by comp name" ${comp_name}  ; #selects the elements from the comp_name component and puts in mark #1
    set elems_list [hm_getmark elems 1]  ; #retrieves the list of elems selected in mark #1 and pass it to a list elems_list
    *clearmark comps 1 ; #clears selection on mark #1
    #do somehthing
    OP
    #do somehthing
    Sir this is like are we setting a component and we are retriving all elemenets of that component. What I want is I select a list of elems through *createmarkpanel elems 1 and hm_getmark elems option and I want to know which component is it part of. Please provide the required code
    OP
    #do somehthing
    It is like whatever component i select and delete it should be able to record and print.Hoping for a help at the earliest
    *createmarkpanel elems 1 "select your elements"
    set comps_list [hm_getvalue elems user_ids=$elems_list dataname=component.name]
    foreach compo $comps_list {
    #do something
    OP
    #do something
    Thanks a lot Sir.
