🎉Community Raffle - Win $25
Join and Win
Non linear spring
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Dears,
          I want to simulate a nonlinear spring. i have an experimental data of force and displacement, have input the data for the spring constant as a curve where the x-axis=displacement, y-axis=force. I have applied a force on the spring, but always getting the same displacement for different values of forces. Can any one help please
1 - 5 of 51
    Altair Employee
    OP
    Hi Aftab,
    The curve is not defined properly in your model. Please check this.
    Altair Employee
    OP
    Aftab,
    FYI, refer to the Defining Non-linear Properties Using Curves in MotionVIew help.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-10795900-1431927120_thumb.jp
    Altair Employee
    OP
    Hi Aftab,
    I have changed the force value in the curve randomly and I can see the change in output force.
    Make sure you have given the right independent variable.
    <?xml version="1.0" encoding="UTF-8"?>post-7616-0-55862500-1431943838_thumb.jp
    Altair Employee
    OP
    Hi,
    I'm interested in the same topic. I need to model a nonlinear spring having a curve. I tried to download the .zip file but it is corrupted.
    What should I do in order to realize a mass spring damper system using a nonlinear characteristic?
    Altair Employee
    OP
    Hi @stefano1
    You can simply create a mass and spring but provide nonlinear curve as suggested
