🎉Community Raffle - Win $25
Join and Win
Connector between shell and solid elements
Rahul_P1User: "Rahul_P1"
Altair Employee
Updated by Rahul_P1
Hey everybody,
I want to perform a linear static analysis on a model consisting of shell and solid elements. The different shell element parts are connected to each other wire rod elements (CWELD, optistruct) to present a weldseam. How can I realize the weldseam connection between the shell and solid element parts? -I tried to take the rod elements as well, but in the output file there occurs an error like 'the chosen grids are no vertex grids'. The use of rigid elements is also impossible, because there are multiple rigid elements connected to a single grid during the automated generation (area + realize) which causes an 'degree-of-freedom'-error.
I´ll be thankful for every comment.
The picture below shows a relevant section from the model.
1 - 2 of 21
    Altair Employee
    OP
    Updated by Rahul_P1
    TKone2013
    Rigids are the best option for your model,
    Follow these steps,
    • Generate rigids automatically from the connectors module > spot or any such method.
    • Go to 1d > rigids > update > switch > (select elements by config for easy selection of all displayed rigids) to ensure that the common node is the independent node. (if your common node is the independent node then don't switch)
    • Go to 1d > rigids > combine > (select elements by config for easy selection of all displayed rigids) > use the combine rigids with common independent node option.
    So now you have rigids connecting your shells with the solids as required.
    Altair Employee
    OP
    Updated by Rahul_P1
    Thanks for your quick answer. The solution is a bit expensive, but it works icon_wink.gif
